configure cfm domain add association meg
configure cfm domain domain_name add association [meg meg_name]
Description
Creates a maintenance association (MA) related to a specified maintenance domain (MD). This command supports the MEG MA format.
Syntax Description
meg ITU-T Y.1731 Maintenance Entity Group.
meg_name MEG name, maximum of 12 characters with 6 bytes ITU Carrier Code and 6 bytes Organization specific Unique MEG ID Code.
Default
N/A.
Usage Guidelines
All ports configured on the specified MEG are now CFM ports in the specified MA.You add the MA, or association, to the domain, and the MA uses the MD level assigned to the domain. Each MA can belong to only one domain, but several MAs can belong to a given domain. The MA is unique within a given domain.
This command was first available in ExtremeXOS 15.5.
Platform Availability
